Hi all!
During the coronavirus lockdown I have a lot of free time so now it's time to rebuild the starter motor
As usual sourcing parts is the hardest parts
I will need the bronze gear, the seals and some cushions,
I found an universal chain 3/8 on ebay will cut as needed
Were do you all usually buy these parts online? Many thanks,
Gianluca
Starter motor rebuild
elektrobank
cosworth
924T
Camel 501
924T
Camel 501
Re: Starter motor rebuild
Here in UK it would most likely be Mdina Italia for the gear and brushes. They took over from NLM for the spares supply. The bearings and seals from a bearing supplier is usually best. As you are in the bikes home country though I guess there will be suppliers more local to you?elektrobank wrote:Hi all!
Gianluca
elektrobank
Here in Italy I can found many parts but unusual parts like the bronze gears is like the unobtanium... Here we have "Cesare luzzi" shop sells only morini parts but you can find belts common oil seals valves but no uncommon partsSteve Brown wrote:
I think I will need to fabricate something for the cushions behind the brake shoes...?
Will Chek on mdina site, thanks
cosworth
924T
Camel 501
924T
Camel 501
In Milano I met Franco Nanni who has lots of Moto Morini spares for sale. He was very friendly and helpful, you could try asking him? I will send you a personal message (PM) with his contact info, if anyone else needs them please ask. I don't want to put them here in public without his OK.
