With the clutch cable slackened off I've noticed the clutch arm has a lot of 'sloppy' movement around the pivot. Is this normal or has the arm worn and if so is there a fix other than replacement?
Secondly, are the orange foam air filters washable?
Normal.With the clutch cable slackened off I've noticed the clutch arm has a lot of 'sloppy' movement around the pivot. Is this normal or has the arm worn and if so is there a fix other than replacement?
If you mean the standard air filters in the box which were originally orange but now might be black or brown plastic.Secondly, are the orange foam air filters washable?
I agree, given they are available at about a tenner each!Undoubtedly the preference is to fit new ones.
yes orange plastic outer parts, its the 500/250 ones that I ordered last were a brownish/black.The filters are orange not brown and look very much like those on Mdina's site so reckon they're new-ish.
