Does anyone have any tips on the best method to remove the Strada instruments from the metal plate that they sit in, each surrounded by a rubber "thing" that I assume might be a bit fragile.
Many thanks, Ian
Instrument removal technique
Ian_C
1974 350 Strada
1975 350 Strada
1983 X1 Kanguro
1975 350 Strada
1983 X1 Kanguro
Re: Instrument removal technique
take the instuments out of the rubber first (the might protest, use a solution of water and dish washing liquid betwwen the instrument and rubber to smooth things up a bit. The you can easily remove the rubber from the plates
Ian_C
Many thanks Hendre, I was trying to remove them as an assembly - your method worked well.
Ian
Ian
1974 350 Strada
1975 350 Strada
1983 X1 Kanguro
1975 350 Strada
1983 X1 Kanguro
