Fastenings, fixings and 0 rings/fibre washer sizes
martinaccarter
Post by martinaccarter »
Hi All
I have a couple of questions arising from changing the fork oil. To remove the fork caps on a disc brake Strada I'm going to need what looks like a 12mm allen key. Before I go and buy one can somebody please confirm the correct size? Thanks
This has led me ask whether there exists a form of "table" for the Strada that sets out all the sizes of the fixings etc along with sundry "circular" items like fibre washers and o ring sizes (I'll need o rings when replacing the fork caps but I have no idea what size - please can someone advise?) My query is also prompted by the fact that I also have a Velocette Venom and many moons ago someone compiled such a table which proves very useful, particularly with regard to the myriad of imperial shapes and sizes involved! Thankfully something we don't have to worry about with the beautiful MMs!
Thanks in advance
Martin
Re: Fastenings, fixings and 0 rings/fibre washer sizes
A useful thing is to download the parts book from the documents in the member’s area. The part number helps when ordering stuff from Mdina Italia.
There is a Marzocchi fork manual at ducactimeccanica website. On my 82 Sport I undo the fork top nuts with a 30mm long spanner, which is not quite the best fit but some bikes have different forks I believe. Someone else should be able to provide other info.
Crankcase bearing sizes we do know!
Good luck.John
For early 350s (and others with Allen socket) I find it easier to use a 3/8 drive ratchet and Allen socket 12mm rather than an Allen key as the clocks get in the way. Go easy as it's not unknown for the heads to shear off. Do undo the triple T top clamp bolts.
Most bolt nut washer o ring and seal sizes are quoted in the parts book, so no need for tables.
martinaccarter
Thanks for your replies. Both very useful indeed
BumbleBee
Post by BumbleBee »
Originally 12mm hex key, but after a lot of use/abuse occasionally a bigger size fits better. One of mine is 12mm the other is likely to round out if I use a 12 so I use something bigger that actually fits that one properly, a bit of empathy goes a long way with old machinery :-)
SupermotoDave
Post by SupermotoDave »
So a 1/2”
BumbleBee
Post by BumbleBee »
SupermotoDave wrote: 25 Oct 2022 16:43 So a 1/2”
On the worn one yes. 12mm on the good condition one :D
This site gives a table of reference for the OR series of o-rings. These can be cross referenced from the parts books. Note these are not necessarily standard metric but can be obtained readily from Simply bearings etc.
I have not validated the entries in this table so you should double check and don't assume that the part
you find in your engine is correct, it might have been replaced in the past.
https://www.thisoldtractor.com/o-rings_uni.html
