For those who have been waiting Aluminium head gaskets for 350s these will be in stock very shortly.
https://www.mdinaitalia.co.uk/M210160.html
1973-1979* 350s originally used a composite gasket and require the fire ring step machined in the top of the liner.
https://www.mdinaitalia.co.uk/M210160C.html
From 1979 the factory changed to use a plain aluminium gasket along with three concentric ring grooves machined in the top of the barrel
Aluminium gaskets can be used on all 350s.
*exact engine number of change is not know but I expect K models to use the later type of gasket
350 Head gaskets - post 1979 aluminium
Re: 350 Head gaskets - post 1979 aluminium
Thank you, Mark. It has been a long time coming. Maybe my base gaskets will get used now!
I had two used sets of gaskets so annealed the head and barrel ones this time around. So far so good…..
