Page 1 of 2
Starter motor chain snapped
Posted: 22 Nov 2023 17:08
by Fastmongrel
Out for a spin today dodging the wet patches on the road came to some lights and engine stopped (think I need to blow through the pilot jets) pressed starter button crunch clang whirr. Whirring noise but no turning engine.
Didn't fancy trying to start the engine just in case something nasty had happened so I pushed the last half mile home whipped off the casing and found the chain had snapped chewing up half a dozen teeth on the clutch and chipping 2 teeth on starter pinion.
- Compress_20231122_170239_9564.jpg (217.99 KiB) Viewed 9230 times
- Compress_20231122_170240_0374.jpg (216.04 KiB) Viewed 9230 times
- Compress_20231122_170239_9167.jpg (72.26 KiB) Viewed 9230 times
I am guessing the chain is a standard size but I can't find the clutch or the starter motor pinion.
Re: Starter motor chain snapped
Posted: 22 Nov 2023 18:39
by Steve Brown
Hi, that's a bind! You're right about the chain being a standard size and I bought one at a local bearing shop. They could only supply with a split link which I have use but keep as a spare now. As for the sprockets, I would like to know if any way of replacing them is found too! I have a couple of damaged examples and even the intact ones I have are worn to the extent it's impossible to tension the chain.
So if any of you know how to replace these sprockets please speak up!
Posted: 23 Nov 2023 08:46
by bigred
Hi my chain has broken several times. Once it punched its way out of the cover. I Shxt myself everytime I press the starter button incase there's another expensive failure. I use the kickstart despite it being painfull on my replacement knee op leg.
Try Mdina italia for secondhand parts. I have purchased several starter chains from them. Also there might be a secondhand sprocket.
Posted: 23 Nov 2023 12:47
by Fastmongrel
I have messaged Mdina l have my fingers crossed.
I have been swinging the Kickstarter and it doesn't seem to spin the engine very fast it doesn't engage until the lever is halfway through travel almost horizontal before it catches the gear. Is this correct or do I need to eat more Weetabix.
Posted: 23 Nov 2023 13:30
by simonnorthroad
Take the kickstart off, and reposition it a spline or two 'earlier', but make sure there's some free movement still, before it engages or you will get a horrible constant rattling noise when the engine is running.
Dont grease the splines and do do the pinchbolt (11mm AF spanner) up well. Please dont ask how I know to give this advice....
Posted: 23 Nov 2023 13:56
by Fastmongrel
simonnorthroad wrote: ↑23 Nov 2023 13:30
Thanks Simon I was thinking of trying that but wanted to check I wouldn't damage anything first.
I feel the pain about pinch bolts I had a foot peg make a break for freedom at cough 70mph officer cough. I had been meaning to pull into the next services to check why it was vibrating so much. Fun times riding the next 150 miles.
Posted: 23 Nov 2023 17:18
by Fastmongrel
Moved the Kickstarter 2 splines and it engages earlier and allows for a good swing. Just need to work on my technique and wear my "start ya bastard" boots.
Posted: 23 Nov 2023 21:11
by MickeyMoto
One question, do you know why the chain snapped?
Posted: 23 Nov 2023 22:10
by 3potjohn
I replaced my chain about 14 years ago. It was worn. I wonder if the chain snapped breaking the teeth of could a tooth have broken first? Either way it is a bit of a tricky situation.
Posted: 24 Nov 2023 00:38
by Fastmongrel
MickeyMoto wrote: ↑23 Nov 2023 21:11
No idea it could have been the original chain for all I know. Plenty of people have said they have had chains break.
Posted: 24 Nov 2023 00:42
by Fastmongrel
3potjohn wrote: ↑23 Nov 2023 22:10
Could be there must be a lot of torque from the electric motor especially as it has to turn the drive 90° which I have been told is never a good thing for electric motor. Basically a bodge straight from the factory.
Posted: 24 Nov 2023 07:22
by MickeyMoto
I always leave slack in the chain, it is easy to havebit too tight. As John says, a tooth may have broken taking the chain with it, but looking at the chain, it appears the roller has pulled out through the end of the plates. It may have seized. I'll have a good look at mine next time the case is off. The chains are not lubricated.
As you say, a bodge from the factory.
Posted: 24 Nov 2023 13:37
by simonnorthroad
Fastmongrel wrote: ↑23 Nov 2023 17:18
Forget usual four-stroke practice.Take up any slack on the kickstart, leave the throttle alone, just jab the KS like starting a two-stroke
Posted: 24 Nov 2023 19:35
by Fastmongrel
simonnorthroad wrote: ↑24 Nov 2023 13:37
I stopped for twenty minutes to grab a coffee this afternoon and after standing in a cold wind it wouldn't start. I think it had cooled enough that it needed a bit of choke but of course with the carb lever it's on or off. Got it going after a few minutes of kicking it's a good way to get warm
Posted: 25 Nov 2023 07:50
by Ming
Gosh - you must have bought a right old dog judging from the problems you are having! In my experience with a Strada, several Kanguros and a 2C2, an electric starter is nothing but extra weight. The bikes should start easily enough on the kick start - if everything else is right. You seem to have a good ignition set up, so I'd suggest looking for problems with the carburettors, the timing (even one tooth out on the cam belt can make a big difference apparently), and have a good watch of all Paul Compton's videos.
I accept that a left hand kick start takes some getting used to, I started by standing to the side and using my right leg, but fairly soon got used to it. The height of the Kanguro kickers was the most awkward, and a 250 you just tread on.
Hope you get it sorted before worrying about the electric one.
