Stuck Ignition Rotor
Posted: 22 Jan 2009 00:39
by mgill
I can't get the rotor off the end of the cam.
Any Ideas???
Posted: 22 Jan 2009 07:19
by hendre
should just slide off..... I would try to put penetrating oil on the cam and then wait and try. Paitience is the key here, ignition pickups are pretty expencive if you can find one :shock:
Posted: 26 Jan 2009 11:21
by mgill
Got it! Once I took the cam belt off and turned the cam sprocket it wiggled off.
