350 not charging the battery
layton
Post by layton »
Hi folks,
My name is Layton and I'm based in Darwen lancs.
I'm a newbie to the site and in fact any site lol!
I bought my first Morini about a month ago. A 1982 350 k2 Italian imported about 2000. It was a non runner with the alternator removed. The vendor believed it wasn't charging. The elderly chap he'd bought it from had given up on it.
I found a receipt stating it had been rewound about 8 years ago by NLM. It looks newly wound with no heat damage. The bike doesn't seem to have been ridden in all this intervening time.
The NLM ignition was goosed so a SACHSE ignition kit, coils and regulator fitted . Sourced from Doug at Mdina, a top fellow who has been a brilliant help.
I've got it running after several attempts to fix the original components. And it sounds bob on.
Unfortunately it's not charging the battery.
There's 30+ volt coming from the 2 yellow leads when measured to earth. 1.5 yellow to yellow.
There's 20+ volts from the red lead measured to earth. The multimeter shows charge when in series to the + battery terminal but connecting directly to the battery there's no evidence of it charging the battery, just the batteries 12.8ish volts. I'm worried about putting high voltage through the harness and cooking the ecu.
120+ volts from the now isolated green.
White goes to earth.
None of the regulators I've fitted have provided a charging current.
I am really at a loss. I've been bodging bikes for getting on for 50 years but this one has got me beat.
Does anyone have a suggestion, or highlight a peculiarity of these machines that could point me in the right direction?
Thanks in advance for any help - Layton
Re: 350 not charging the battery
Have you a copy of the Blue book Morini manual?
According to the section on testing for correct charge function, you should be getting around 8amp with the meter connected in series to the red lead which goes from the generator to the battery at 6000rpm.
Disconnect the three leads, 2 yellow and one red coming from the generator. At 6000 rpm you should get around 60v across the two yellows and around 30v between a red and a yellow.
To partly check the regulator disconnect it and put the meter across the two yellow terminals. Should be zero resistance.
At least this is my understanding. Thus far I have never had a charging issue.
Are the fusebox terminals good and clean with no wobbly terminals and sound fuses?
Also search “Strada not charging” on this section. This should link
viewtopic.php?p=23862#p23862
layton
Post by layton »
Hi 3potjohn,
Thanks so much for getting back to me so quickly.
I've just been outside annoying the neighbours lol!
Red to battery+ amps = no response at the multimeter.
Yellow to Yellow 2.1v
Yellow 1 to red 4.5v
Yellow 2 to red 2.5v
White to earth 0.04ohm
Yellow to Yellow resistance 0.90 mili ohms.
Yellow1+2 to red nil resistance response.
At face value does the alternator need rewinding or the flywheel need re-magnetising perhaps. The bike had been with NLM for various jobs, Valves had been set but had zero clearances, the starter stripped and overhauled but the starter chain was hanging off. I guess everyone has an off day but maybe the rewind wsan't done properly?
I'll have a look at your strada suggestion now.
Again thanks for your help- Layton
layton wrote: 06 May 2024 10:11
Hi Layton welcome to the mysterious world of Italian electrics
Lets make sure as the numbers look a bit odd above can we redo the measurements
So please recheck the measurement suggested by John
Disconnect regulator and battery from stator remove yellows and red and leave disconnected
In the disconnected state start engine and at 6000 rpm (if you and neighbours can bear it)
measure at the stator leads, take care not to short them.
Yellow1 to Yellow2 , it should read 60V a.c rms
Yellow1 to Red, it should read 30V a.c rms (actually it should read half of the Y1 to Y2 reading)
Yellow2 to Red, it should read 30V a.c rms (actually it should read half of the Y1 to Y2 reading)
Now if these readings differ greatly then check the resistances.
Y1 to Y2 should be less than 1 ohm
Y1 to R and Y2 to R should be less than 0.5 ohms and in any case about half of the Y1 to Y2
Next find a 60W 12V bulb and put across Y1 and Y2 - take care! the bulb should light nicely, dont leave it too long though
If the resistances are good but the voltages are low below half above then you are right to suspect demagnetisation
Assuming the measurements are good
Next find a part number of the regulator if there is one its the one that starts like 34XXXX,
if not if it is a flat plain unfinned regulator that's OK.
There are two types of systems on road Morinis for now we shall call them 3 wire and 2 wire the standard on 350 roadbikes is 3 wire and uses ALL stator wires.
The 2 wire is used on 500s, a great number of 350s have been upgraded to use 2 wire systems and the regulator changed
NLM used to sell 2 wire regulators to replace the old 3 wire ones. Most aftermarket are 2 wire.
2 wire are single phase, 3 wire are so called 2 phase. 3 wire system is antique.
In order to a get the regulator to work and b) avoid frying it we need to make sure exactly which system you have
(a picture would help)
If its a plain sided unfinned regulator then you can go ahead and try to make it work
Connect the regulator and stator, the Y1 and Y2 from stator goes to terminals labelled G (grigio is Italian for yellow) in any order.
The Red from the stator goes to fuse box, which hopefully is also connected to both the battery and the main switch,
sometimes there is an inline fuse, but since you can run the engine this should be ok
In the three wire system the R/B+ terminal of the regulator IS NOT CONNECTED to anything when there is a fusebox
In fact its there only for machines like the 250 which don't have a fuse box.
On the regulator there is needed a Control input (C) this is a brown wire connected to switched 12V, make sure its there and has 12V when the main switch is on, the regulator cannot work without it. The regulator must be properly earthed - this is done via its case on original regulators.
Since you have Sachse system the green and white wires from the stator are not required
If you have anything other than the plain regulator we must first work out whether it a 3 wire or a 2 wire as the connections are different.
I can advise on how to measure the regulator to confirm which type it is. If its an unbranded generic thing then its most likely 2 wire.
Mark Bridger
BSc Elec Eng
layton
Post by layton »
Hi Mark ,
Thanks for your detailed instructions, I hope I've carried them out properly!
I just revved to 6000rpm very briefly, the locals are sharpening they're pitch forks haha!
Multimeter set to AC.
Yellow 1 to yellow 2 = 2.7v
Yellow 1 to red= 5.7v
Yellow 2 to red 3.3v
Yellow 1 to yellow 2 = 0.09 ohm
yellow 1 to red= 0.06 ohm
yellow 2 to red =0.06 ohm
Yellow to yellow with h4 55/60 watt bulb = did not illuminate at all.
Regulator is 34 41 14 50. 12 volt 12 amp Ducati item. I have taken the SACHSE unit off at the moment as don't think the original is goosed (yet!)
The regulator was wired 2 yellow in and a brown ( which is a switched 12v and working) to the fuse box. The central red is just a two bladed return with no internal connections. Let me know if you need photos I'll ring the kids to find out how lol!
I hope you can make head or tail of this.
Thanks Layton.
layton
Post by layton »
Hi everyone,
Still no further on with the battery not charging.
Rex's speed shop - Top fella! tested the stator and resistance was all good and didn't need work. He said he'd never seen a flywheel lose it's magnetism in 30 years, and to be fair it seems pretty strong to me. But a few of the posts talk about re-magnetizing the flywheel so is there something specific about morinis?
I haven't been revving it to 6000 just out of mechanical sympathy but 4000+.
The yellows put out 25v+ ac to earth
yellow to yellow 2.5v ac
yellow1 to red 5v ac
yellow2 to red 2.5v ac
green 270v ac
red 15v dc to earth or +ve battery.
Connected up through the regulator the battery voltage stays at 12.2v. It wants a bit of a charge up.
There has to be something about the alternator I'm missing but I can't figure it out. I'm loosing what's left of my hair lol!
Has anyone got any ideas?
Its Whisky time!
Cheers- Layton.
Hello Layton,
apologies for slow response have been away - its riding season!
The very low resistance values and the lack of measured volts seems to imply that the stator winding insulation has burnt out - i.e short circuit turns.
I measured a known good stator and it measures Y1-R 0.4ohms, Y2-R 0.4ohms, Y1-Y2 0.8ohms - did Rex's speed shop give you the actual measurements, how did they know it was good.
So let's give them the benefit of the doubt and say the stator is good.
Further measurements are in contradiction with previous and to be frank I can't make any sense when there are different results each time.
Are you perhaps mis reading your multimeter or there is a divide 10 setting?
Since at 4000rpm 25V, 25V and 50V would be acceptable with no load, meaning stator disconnected.
and demagentised stator would not be suspected, in any case this only really affects the CDI system which is more sensitive than scooters to low voltage supplied.
Is the battery new and fully charged? Battery negative is connected to chassis and there is no fuse.
"red 15v dc to earth or +ve battery."
Now if you are seeing 15V on the battery +Ve when measured with respect to chassis earth then this is higher than expected, it should be around 14.4V to avoid boiling the battery. But 15V across the battery would generally mean the battery would charge! Ideally you would measure the current flowing into the battery with an ammeter in series. To avoid any damage by sudden disconnection please ensure that the ammeter cannot be disconnected accidentally with the engine running so make up suitable leads to facilitate this.
If there is a high voltage across the battery - but a battery refusing to accept charge it would mean a heavily suplhated battery, so to make sure the battery is properly charged and gassing freely before making any more attempts. Ducati regulators are not designed to recover tired batteries.
The regulator is a Bi phase as there is no internal connection which is correct.
layton wrote: 06 May 2024 13:53
Previously you stated
layton
Post by layton »
Hi Mark,
I hope you had time for a decent ride out. I had a week on Tenerife, hoping it would heal itself in my absence . Alas no! Lol!
Rex's speed shop tested the resistance with no mention of running on a rig.
They reported - Source coil 304 ohm. Charging 0.5 / 0.5 / 0.9. So far as I know that's fine.
The battery was NOS from the Stafford show and puts out serious voltage / Amps and has been on charge.
Previous outputs I recorded were variable due to my reluctance to rev to 6k, so please forgive my incompetence. Electric's aren't my first language Lol!
Today I've run it up to 6k as closely as I could. at which point the battery shows 12.58v DC rising to 12.8v DC at tickover showing the ignition is drawing charge.
The Amperage with ignition on not running was 4.2 amp . At 6k 4.9 amps. Measured with brown and yellows connected at regulator red to the loom, bridging through the meter + lead to battery +ve.
At 6k all alternator leads disconnected from the loom except white earth.
Y1- to earth 30.5v AC
Y2- to earth 31.5v AC
RED- to earth 30.7v AC This seems odd as previously it was DC ?
Y1 to Y2 3.0v AC
Y1 to Red 2.9v AC
Y2 to Red 6.2v AC
Green to earth 300v AC
White earthing.
I hope these readings are more useful.
I'm seriously thinking of letting Thorncraft motorcycles have a look, Steve has been really helpful in the past. I haven't had anyone touch my bikes in 30 years but senility might be setting in Lol!
If you have any insights Mark I will give it one last try.
All the best- Layton
Hi Layton,
Thanks for confirming the measurements from Rex's, the stator is good.
Whilst the measurements dont entirely make sense and there is a whopping 50W being dissipated somewhere.
Is the headlight on?
If not then it could be that the 50W is being dissapated in the regulator or in the stator or both. Is the regulator hot to the touch?
Unless there is a wiring fault it looks like the regulator is faulty. You should try to obtain a replacement regulator these have been obsolete for decades so you might have to use a secondhand one. As an alternative you can use a standard generic single phase regulator, this requires some minor wiring changes.
I think you should determine where the large current draw is going to before substituting the regulator.
layton
Post by layton »
Hi Mark,
sorry for the delay replying to you , I've been away.
I put the SACHSE regulator on with no change to the output. It only uses the yellow wires if I remember correctly. The red and green isolated.
The regulators didn't seem to get hot and the headlight was switched off.
I think you are right in saying the current is going directly to earth through the harness though I couldn't see anything obvious.
The red wire is a worry, sometimes showing AC then on another occasion DC! It is unregulated going to the loom . I can't imagine how this can be correct.
I have had problems with 2 Sachse ecu's dropping the front cylinder. They could have been duff or been overcharged by the red wire. I was very cautious so I don't know.
The bike has been at a local repair shop for the last week, the owner is very experienced and I've known him for decades. He's not found the problem as yet so it's not an easy fix .
If you have any ideas I will pass them on or take them up if it comes back unrepaired. If it's fixed I'll share the outcome with the group.
All the best Layton.
I’ve been following this for a while and your latest post made me think. From previous topics on ignition I had the impression that the Sachse unit did not use the source coil output (green) and that the regulator was changed for a modern single phase one (ie using yellow / yellow). If that is the case your red connection from stator should be isolated and tucked out of the way, similarly the green. Any connection of the red is a potential short circuit.
If all this is incorrect, I’ll go back to observer mode. :oops:
Sorry, early morning and I still have bleary eyes. Ignore above...
layton
Post by layton »
Hi Ming,
yes your right the Sachse regulator doesn't need the green and red so I isolated them. As the Sachse unit wasn't providing a charging voltage for the battery I reverted to the original regulator in an attempt to keep things simple . It didn't I'm afraid!
Thanks for your message- Layton.
layton
Post by layton »
IT'S FIXED !!!
Can I give a massive shout out to everyone who's offered advice on the non charging alternator! And a special thanks to Paul Compton for
re-magnetising the rotor.
Doug at Mdina Italia was endlessly helpful too and has to be first port of call for parts.
The top fellas at Rex's speed shop found one of the coils had been rewound in the wrong direction and rectified it for me.
I've taken the bike for it's first shake down ride this morning and it's lovely! When I manage to rewire my brain to right hand change it'll be perfect for the trough of Bowland run.
I've been after a Morini for decades and it's just as good as everyone says!
Again thanks everyone!
Layton.
That is good outcome and soon the weather will pick up too then you’ll have a great year ahead.
