Gas tank rubber retention ring
Posted: 30 Mar 2025 00:23
by Tresette61
Members, any one know where one can acquire the rubber retention ring which holds the rear of the gas tank in place? I see Mdinaitalia lists it on their web site, unfortunately they are out of stock. Mine has finally broken.
Regards Clark Bertram
Re: Gas tank rubber retention ring
Posted: 30 Mar 2025 00:35
by FatherB
I've used Hoover vacuum cleaner rubber drive belt rings for years. They do the job on my Strada and seem to last quite well. The one currently on my bike has been there about 5 years and is still good. Your local vacuum cleaner spares stockist should be able to sort you out with one.
Posted: 30 Mar 2025 15:13
by Tresette61
Father B. thank you for the suggestion. I will check out Hoover vacuum parts vendor.
Posted: 30 Mar 2025 15:58
by Martha
An alternative that I have used is an 'o' ring of suitable dimension sourced from ebay.
Incidentally, the foam rubber pad(s) that sit under the tank on the frame spine are close enough to those fitted for the same job on the 750/850 Norton Commando and the rubber buffers at the rear corner of the tank are as near as dammit those fitted to Norton Dominators.
Posted: 30 Mar 2025 19:31
by Steve Brown
Yes, as already said-washing machine/vacuum cleaner spares! As for the support pad the originals will have crumbled away years ago and were only a cheap piece of porous foam anyway. I started cutting up old camping mats-closed cell foam and cheap enough. The originals were also a bit marginal on thickness and I find 2 x camping mat bits cushion it nicely. I don't camp much these days either!
Posted: 30 Mar 2025 19:46
by 'It must be a .....'
For years I've been using the the large rubber seals from car oil filters which last for years.
Worth asking at a garage if you don't do your own car oil changes.
Posted: 31 Mar 2025 10:07
by Vitesse
Mine has a piece of rubber clearly fashioned from inner tube. Not pretty with a big knot in it but effective.
Posted: 07 Apr 2025 20:19
by BumbleBee
Mine simply has a wide black cable tie
Not tight, just enough to allow flex on the rubber foam the back of the tank sits on.
