350 K2 Brake Pads
KiwiChris
350 K2 Brake Pads
Post by KiwiChris »
I’m soon to be recommissioning a 1984 350 K2 that’s been in storage for 11 or so years. I’ve got most of the stuff in hand that I’ll need but I am struggling with tracking down new brake pads. The calipers are the standard Grimeca units. From the pictures received, they look to be using the two pin type brake pad. Discs themselves are the standard chrome plated, drilled and will need a good clean up. Mdina don’t have stock. I have 3 questions for the hive mind.
1. Recommended supplier for Grimeca pads
2. Good alternate make of pads
3. The preferred compound for use on chromed discs
Thanks in advance for your help.
Daddy Dom
Re: 350 K2 Brake Pads
Post by Daddy Dom »
If you didn't find this thread yet, have a look here.
viewtopic.php?t=5705
I think I also have some packaging from old sets that may help with ref.numbers.
Dom
KiwiChris
Post by KiwiChris »
Hi Dom, thanks for the info. Very helpful. I’ll see if the supplier mentioned is still on business, if so, I’ll be ordering up new pads F&R. Thanks again. Are you by chance an IMOC member?
