I have just rebuilt the engine on my 3 1/2 drum brake sport and I have a problem with gear selection. The motor is back in the bike with everything back on apart from the barrels. I followed the manual very carefully when building the moter- the gear cluster and selector forks are in perfect condition with no visible wear, the gear lever moves smoothly up/down and it returns to the centre position after selecting a gear. When I try to select the gears while turning the back wheel slowly there seems to be a neutral in between every gear and it doesn't seem as though there are 6 gears in there..
Obviously I'm a bit worried about this as I don't want to finish the rebuild only to find there is a gearbox problem that needs another strip down.
Has anybody else experienced this? Is it possible to install the gear cassette such that all of the gears can't be selected?
Thanks for your help,
Dave
