fork seals
fork seals
how easy are the fork seals to replace - I have done them before on previous bikes but it isn't a job I enjoy- thanks - dunk
dunk
Brute force and ignorance help a lot.........
Screwdriver as a lever under one end and ping it's somewhere in the garage/field/gravel.
One end has a very slight chamfer (or at least mine did) which a blade can be forced under - presumably these rings were slightly cheaper than conventional circlips.
As to replacing make sure you have the correct seals - may need to be 7mm deep not the more common 7.5mm deep depending on the forks - mine were 1978 Marzocchis. Thicker seals prevent circlip going back in.....
robint
I've had a few forks done by Philpot's Hard Chrome (they're almost within walking distance), but not been 100% satisfied by the finish.
Disco Volante can do you Paoili/Tarozzi stanchions new for not that much more, so that's the route I'd go in future.
