For Sale 507cc 5 speed
harrymuffin
Post by harrymuffin »
Built up in the last century using a 5 speed bottom end and brand new 507 barrels, pistons and heads. About 3000 miles since 'new'. Engine internals polished piston skirts chamfered and polished internally, inlet valves seats narrowed and rediused, steel carb stubs 'bent' fitted with 28mm carbs, inlets gas flowed. Proper oil filter fitted, starter motor that works, starting on the button instantly. Cibie headlamp, taper head bearings, Cuppini levers on Verlicchi fully adjustable clip ons, Grimeca double sided front brake, early rear light. Historic registered - no tax or MoT. Currently equiped with Smiths chronometric clocks but can provide brand new Veglias that were fitted, also oil pressure gauge and idiot light when ok to open the engine up from cold. PM and more information and photos and inspection. Offers.
