Chokes with handlebar lever
Posted: 13 Jan 2015 14:35
by MarkB
Taken from the PHBH 28s on my 501 motor, but the dimensions appear identical to the 350 chokes. Handlebar lever and back-plate included; you'll just need a bracket. This pivoted on the clutch lever pivot bolt. £20 including p&p in the UK. PM me with any questions. Thanks, Mark.
Re: Chokes with handlebar lever
Posted: 14 Jun 2015 03:42
by sheddweller
Hi Mark,
Did you sell these chokes? and are you prepared to post them to Australia at my cost?
Garry Roberts
Posted: 14 Jun 2015 18:20
by norbert
I Think you can use them also with a Dellorto 25.
I´m dealing withe the same subject because the normal choke lever bump to the aluminium petro tank taht I´m goin to use. My problem stays the same because the height is the same even using the curved tubes on the carbs.
But trhere is a little diference between the choke pistons, they are longer withr the cable ones as you can see on this picture:
- k-DSCI0152.JPG (52.69 KiB) Viewed 6597 times
ciao norbert
Posted: 17 Jun 2015 13:37
by MarkB
Hi Garry
Sorry for the delayed reply. The chokes have now gone.
