Jiffy, a bit shop spoilt on the paint, but definitely new. Total length = 27 cm, fitting for spring sits at 10 cm's from the top. Fit's bot 350 and 500, but maybe also fit 125 and 250. Part number = 45 02 21
30 Euro's
NOS Rear Axle ⦰ 15 mm, so for older models with wire wheels. Overall length = 27,5 cm's and the small part with threaded end measures: 47 mm. Part number = 43 05 17
20 Euro's
Manifold inlet new for early 350: 6 Euro's
Early type engine mounting plate, only left ones unfortunately. New bit shop spoilt on paint. 10 Euro's
Brackets new for chain guard, fit's stainless and plastic rear chain quards for almost all models up to 500. 6 Euro's
NOS heat shield for 350 K2, but will fit all 350 models. 20 Euro's
tomros@live.nl
the Netherlands
