SOLD: First series Gaskets (base and head)- clear out
Posted: 10 Oct 2020 09:47
by mbmm350s
NOS 1st series gaskets, fibre with copper fire ring on the head gasket , only for use with stepped liners as in picture.
62mm for 350 up to 1979
13 pounds including UK postage.
The cognoscenti always check the lower gasket of original machines. :wink:
I have also one 66mm fibre head gasket - free just pay postage.
Re: First series Gaskets (base and head)- clear out
Posted: 10 Oct 2020 20:46
by Stubaker58
Hi Mark,
I’d be interested in the gaskets. PM sent
Posted: 12 Oct 2020 14:03
by mbmm350s
Stuart,
PM sent, do you still want?
Posted: 12 Oct 2020 15:01
by bizzywizzy
If Stuart doesn’t want them I would like them.
Mike
Posted: 12 Oct 2020 18:45
by Stubaker58
I’m not sure they are right for my bike (it’s a’79) so you take them.
Stuart
Posted: 13 Oct 2020 07:16
by mbmm350s
Thanks Stuart,
The factory changed to the aluminium gaskets around 79.
This would be about the time of 350 electric start introduction and other engine changes
The blue manual published 1979 I think, clearly shows aluminium gaskets being used.
and in use on earlier engines, which is fine, if you use the sealant.
Athena list the gasket 1974-1978.
http://www.athenaparts.com/eng/products ... ead-gasket
I have 2 engines of the 14XXX range that are from 78 with the stepped liner.
Posted: 13 Oct 2020 11:49
by mbmm350s
Mike PM sent
Posted: 13 Oct 2020 18:09
by bizzywizzy
mbmm350s wrote:Mike PM sent
Hi Mark,
I replied earlier.
Mike
