I'm after a tank for my 1977 350 strada, I think this is the same as all early 350s. Please someone correct me if I'm wrong. Not too fussy, just needs to be solid and petrol tight (but no pet seal / liner). Mine leaks like a sieve and has a dent that I reckon is too big to fill.
I'm also after gear pedal / foot rest and linkage for the same bike, current one is very warn and sloppy. I've attached a photo as all the photo of stardas I've looked at appear to have a different setup with the pedal attached directly to the gearbox shaft.
cheers
Bob
Tank and foot rest / gear pedal 1977 350 strada
bobajob
- footrest.jpg (233.69 KiB) Viewed 8724 times
Re: Tank and foot rest / gear pedal 1977 350 strada
For the linkage, just buy two 6mm rod ends (like these)
http://www.ebay.co.uk/itm/M6-Female-Rig ... 1c31f423bc
bobajob
Thanks for that EVguru. I've also found a friendly machine shop that will bush the gear pedal. So combined with the rod ends that’s the gear selection sorted.
I don’t think the tank will be so simple to sort……
I might have a spare tank without any use... I'll try and dig tomorrow in the pile of morini stuff...
bobajob
Thanks Henre
bobajob
Looks like we're sorted Hendre has a tank and a I've got some one bushing the gear pedal.
