Gear shift lever for 250 vee
buzby
Post by buzby »
Can anybody help me with this ? It seems to be unique to this model. The lever pivots on the footpeg and connects to a linkage.The part number is 450251.
thanks, Dave.
David
Re: Gear shift lever for 250 vee
Ming had one off me that I had slung in the spares shed years ago. They do appear to be currently unobtanium even on Ebay.it. The good news is that if you can only find one with a very worn pivot they can be re-bushed fairly easily.
A skilled welder could probably fabricate one from tube from a drawing and dimensions.
Heh, heh. I do have the 'modified' assembly that came with the bike. It could be repaired with a bit of skilful welding (it's the one on the right).
