Would anyone have the connector pipes and joiner/bush from the carbs to the airbox for the 250 2c v twin. Both sides needed. Part No 30.01.61 x 4 and part No 32.01.48 x 2.
Richard Parker
250 2c carb to airbox manifolds
- Parker3865
Re: 250 2c carb to airbox manifolds
Ive got one Richard, if you dont find two used. Im in Bath
- Parker3865
Thanks, I'm in Brentwood,. My daughter at Uni in Bath so I'll let you know if I need it and talk about price than. Many thanks.
Startgomma has those for 125's, don't know if they are the same?
Hello Richard
30.01.61 is same part on Kanguro X, airbox side.
The coupling ring is just a hard plastic stiffener thing - you can 3D print that!
I can measure one for you if needed if no one has them.
The 250 2C uses the two right angle parts coupled together, using the stiffener ring- bingo!
replacement Kanguro part is here:
https://www.startgomma.com/en/manufactu ... ESC&page=3
Buying 4 is a little bit expensive , so hopefully some kind souls have Kanguro ones.
- Parker3865
Thanks for that, very useful information. I'll come back to you about dimensions of the connector if I need to.
As far as I can see, 30.01.61 is the 90 degree rubber 'elbow' with MM50 moulded in so yes the same as the Camel Start Gomma V619?
For some odd reason I have 3 used ones in the odds and ends box in the shed. There must have been four when I 'broke' the 250 that became the Forgotten Error. No stiffening rings though.
I won't be using them. Postage will be about three quid.
PM me with an offer.
- Parker3865
Many thanks for all the help. I am sorted now, thanks to the community.
