Front fork stanchions / front mudguard
Hi all, due to a coming together of myself / Morini and immovable object I need some 35mm stanchions and front mudguard for my 81 500 Sport. Anyone got any to assist in a rapid return to the road ?
Steve.
Steve.
Re: Front fork stanchions / front mudguard
Hi Steve.
Sorry to hear of your mis-hap.
I have a steel front mudguard which I may be willing to part with. It is a little bit scruffy with some paint loss but fundamentally sound.
I bought it for my 3½ but I imagine the 500 ones are the same. If you want to check, the mudguard is 132mm wide where it bolts to the forks. The bolt holes are 9mm diameter and 53mm centre to centre.
Photos here...
Photos here...
- DSC01703r18.jpg (245.62 KiB) Viewed 77 times
- DSC01704r18.jpg (252 KiB) Viewed 77 times
- DSC01705r18.jpg (247.51 KiB) Viewed 77 times
- DSC01702r18.jpg (241.4 KiB) Viewed 77 times
Hi Jen, PM sent.
Steve.
Steve.
I hope you didn't hit our Prime Minister. Joking aside, hope you are not damaged.
I’m fine thanks.
Glad to hear you are ok Steve. Depending how bent they may be able to be straightened. I had a frame straightened by motoliner and they did forks too. I think there are other specialists too.
Good luck, see you on Thursday.
Thanks Robin, I think they are too bad unfortunately, but I shall bear it in mind.Fingers crossed may have replacements soon.
Steve.
Steve.
