Putting my '78 model Strada back to good running/riding order. The side stand is missing, and having to find a flat piece of ground and then haul it up on the centre stand every time you want to park is starting to get a bit wearying.
Would anybody have a side stand - ideally with the proper bolt /spring combination - they'd consider letting go ?
Anybody got a sidestand for a 3 1/2 ?
A BigVee, a WeeVee, and a triple.
Re: Anybody got a sidestand for a 3 1/2 ?
Hello AK99.
Welcome to the Forum.
Mdina Italia have some reproduction side stands in stock. Here is the link...
https://www.mdinaitalia.co.uk/morini-35 ... ction.html
Best regards,
Jenny.
Best regards,
Jenny.
Thanks Jenny
I see they have the spring as well (albeit at a racy £17 plus VAT). Will have to give them a ring and see if it needs the original bolt - and whether they stock them too.
If you are a member you can receive a discount from Mdina! Every cent helps... especially during a restoration!
https://morini-riders-club.com/theclub/MRC.html
ianlucas006
Hello
I have almost certainly got a stand. Probably a bolt as well. Will have a look later.
Thanks Ian
Thanks Ian
ianlucas006
I have found one complete with bolt. Not looked for spring yet. I had a look at the Mdina replica. Not very impressed. Bottom detail all wrong
Agreed.ianlucas006 wrote: ↑21 Oct 2025 18:10 ... I had a look at the Mdina replica. Not very impressed. Bottom detail all wrong
Pleased to hear you have an original one to pass on, Ian.
