Wanted inner clutch cover and seat for 83 sport
Looking for an inner clutch cover its for an 83 84 bike also a decent sports seat
Re: Wanted inner clutch cover and seat for 83 sport
Do you mean the primary casing that has the clutch basket and primary drive gear either side of it? I may be able to help.
Hi hobnob.
Welcome to the Forum.
Are you looking for a K1 seat, as in the attached photo? If so I have a seat and the fibreglass base and storage box thingy, but not the lock.
The photo is of another bike, but if it is what you are looking for I will take some photos of the one I have.
Jenny.
Jenny.
- K1 Seat.jpg (47.44 KiB) Viewed 2849 times
Hi Steve, Would you be able to send me any pictures of the casing please?..my bike is an 1984 500 has an external oil filter fitted and I want to go back to standard where are you located?Steve Brown wrote: ↑17 Nov 2025 17:59 Do you mean the primary casing that has the clutch basket and primary drive gear either side of it? I may be able to help.
I'll have to get some pics, and I am near Lutterworth in Leicestershire.hobnob777 wrote: ↑18 Nov 2025 16:23Hi Steve, Would you be able to send me any pictures of the casing please?..my bike is an 1984 500 has an external oil filter fitted and I want to go back to standard where are you located?Steve Brown wrote: ↑17 Nov 2025 17:59 Do you mean the primary casing that has the clutch basket and primary drive gear either side of it? I may be able to help.
I'll send pic of my bike I think it may be the same as 83
Yes thats the one Steve
[/img]
hobnob777 wrote: ↑18 Nov 2025 22:57I'll send pic of my bike I think it may be the same as 83
this picture is NOT my bike its the seat style Im looking for
Hi honbob.
Yes, I don't think the year matters for the 500s, you just need to specify that you want a 500 Sport seat (with the hump) rather than a 500 Strada seat (which is flatter).
The seat I have is off a 350 K1 Sport and is completely different. The lock is on top of the ducktail, and when unlocked the whole seat lifts off.
The earlier 350 K Sport seat looks similar to yours and hinges on the left side with a lock on the right side, but I suspect that a 350 seat may be shorter than a 500 one, although I don't know for sure. Having said that, I do have a 350 K Sport seat (in terrible condition) which I could measure tomorrow.
- 1982-morini-3-12-k1-r50.jpg (178.88 KiB) Viewed 2708 times
I have a standard primary cover, if you need one.
Im in Bath tel: 07788 442155 but happy to post
Simon
Simon
Could be the same, check the picture i put up of the seat im looking for.
Yes Steve thats the one I needSteve Brown wrote: ↑17 Nov 2025 17:59 Do you mean the primary casing that has the clutch basket and primary drive gear either side of it? I may be able to help.
OK thought so. I should be able to offer either a 500 or a 350 type. The only difference is whether they have a tapping point for the oil pressure switch. I 'should' be able to check on either Sunday or Monday and let you know. If it makes any difference, any castings I have will be in need of a thorough cleaning/vapour blast to make pretty.
Well, I've measured the 350 Sport seat and here are the dimensions:-
Overall length - 660mm.
Width at widest point - 290mm.
Outside of hinges - 260mm.
Between hinges - 152mm.
- DSC01794r12.jpg (130.85 KiB) Viewed 2504 times
- DSC01339r12.jpg (148.97 KiB) Viewed 2504 times
- DSC01338r12.jpg (171.71 KiB) Viewed 2504 times
