500/350 clutch hub
raptor
500/350 clutch hub
Post by raptor »
Just wondering if anyone has a clutch hub for a 500/350, i think they are the same. By hub I mean the centre of clutch assy with the studs in it. Or if not a complete clutch unit . Thanks
Re: 500/350 clutch hub
No, not the same, the 500 gearbox (5 or 6 speed) has larger input and output shafts.
Why do you need one?
raptor
Post by raptor »
Hi,thanks for the reply. The centre hub was damaged at the base of one of the studs. I had it repaired, but it now fouls the operation of the clutch springs, even after trying to modify. So a replacement is the way ahead. Thanks again
