Kanguro - Front Cylinder Push Rod
Posted: 05 Feb 2016 23:05
by jb666
The nice shiny bits to resurrect the Kanguro arrived from NLM but they didn't have any front cylinder push rods. Anyone got one available?
Re: Kanguro - Front Cylinder Push Rod
Posted: 08 Feb 2016 19:51
by hombre
They are probably the same as in all 350's (someone correct me if I'm wrong).
I have one for you...
Posted: 08 Feb 2016 21:12
by norbert
They are the same in all 350 motors, with the dirference that in the early motors they were 7mm, later 8 mm turned down to 7 mm at the ends to fit the steel endings. The old ones were 5 gr. lighter 30 in spite of 35 gr. (the main reason to me apears to be the smaller iron part at the upper end)
The rear pushrods are about 2 mm longer. The sizes over all front/rear:
500 und 250T: 205/207 (therefore the 250T should be 205)
501: 202/204
350: 182/184
ciao
Posted: 18 Feb 2016 20:24
by hombre
I have these, they vary a bit in lenght :D but should all come from 350-engines
