looking for fork oil seals for the 250 2c (1985)
They seem to be pretty hard to come by, does anybody have an idea? Thanks for any replies and happy riding!
Re: looking for fork oil seals for the 250 2c (1985)
I think I found them on ebay - not specific to Moto Morinis, go by size.
If I can find them I'll let you know.
350 seals are 35mm X 47mm X 7mm, i seem to recall the 125/250 selas are 32mm X 47mm X 7mm. You need 4 as you have to stack up 2 to fill the room in the leg
check your old seals for correcr measuremtns and go to a good bearing shop to get replacements
if you can only get 32x47x10 seals then you buy two and make a 4mm filler ring from the old seals
https://www.bearing-king.co.uk/bearing/ ... pring/4529
