Camel stuff wanted
hombre
Camel stuff wanted
Post by hombre »
Hi all, I am after some stuff to finish one 500 Camel and start the build of a 2nd...
airfilters
housing complete with filters
rear brake cables
tachocables
the rod that keeps the rear brake in place 19.02.39
left footrest, or just the part that attaches to the frame
dashlights
brake pedal
a longshot mx580 390mm
and a very longshot.... two Valentinimufflers for a 2-2 system
one headlightclamps 38mm
rossguzzi
Re: Camel stuff wanted
Post by rossguzzi »
Air filters are available new from MDina. Beware if using them in dusty (Australian outback) conditions. I believe the air filter housings are hard to find now.
I would be interested to know if there is a rear brake cable supplier too.
Good luck with the build
Cheers.
hombre
Post by hombre »
I am living below sea level, so hardly any dust ;) Thanks for the tip though!
BumbleBee
Post by BumbleBee »
rossguzzi wrote:Air filters are available new from MDina. Beware if using them in dusty (Australian outback) conditions. I believe the air filter housings are hard to find now.
Cheers.
Venhill Cables used to have Morini cables of all sorts on their books. Drop them an email they may still have the measurements to work from. They were reasonable prices. Failing that they do one offs from drawings or from worn out ones, though this service is more costly. They are at www.venhill.co.uk
hombre
Post by hombre »
Thanks for that, the Camel isn't listed but I'll give it a go. If I am not mistaking some cables used on Guzzi's are usable on Morin's too. I'm still after the rear brakecable and one for the tacho.
