Clutch tooth washer
Clutch tooth washer
Has anyone got a new clutch tooth washer for a 501 camel? MDINA are out of stock, why can't I post a picture
Re: Clutch tooth washer
Hi Ivan,
Do you mean the lock washer 15.05.38 ? same as 500?
Hi Mark yes it's the clutch thrust washer, I have a replacement now but always good to have another
Mark I have part number m33. 01.44
The reason they are out of stock is likely my fault as I bought 3 a few weeks ago.
Would this be part 32.01.44? oddly described as a tooth washer in the Kanguro X manual...
If so, there doesn't seem to be any sign of them on mdina's website. @3potjohn might hold the remaining stock of them. Anyway, I need one of the plastic thrust washers that goes between the inner and outer clutch baskets if anyone has surplus.
Mdina call it a "clutch spider" for some reason but show out of stock.
https://www.mdinaitalia.co.uk/M320144U.html
Kamel.
Kamel.
