Dart ammeter wanted
Posted: 04 Aug 2021 13:14
by clanger9
I'm looking for a Dart ammeter. Not working is fine - I just need the outer part.
Let me know if you've got one...
Re: Dart ammeter wanted
Posted: 04 Aug 2021 17:46
by morini_tom
Ammeter? A Dart doesn’t have an ammeter. Do you mean oil temperature gauge? The smaller one on the right hand side of your dash cluster of 3 instruments. Or has your dart been modified.
I might have a spare oil temp gauge but possibly with a broken case or glass. What bit of it specifically do you need?
Posted: 04 Aug 2021 17:56
by clanger9
Really? Wow, mine does!
Now that I look at it carefully, does indeed look like a mod. It doesn't match the other instruments. I just figured they were all like that.
Which explains why I couldn't find another one anywhere...
I'd upload a photo, but the forum doesn't want to play today.
Posted: 05 Aug 2021 11:25
by morini_tom
- 8BEBA5F6-2148-4DAA-AA1C-2B2CF0956EB2.jpeg (141.43 KiB) Viewed 5919 times
This is what a dart dash should look like (ok ignore the different top yoke and bars, and the fact the dash is set a bit lower in the subframe as this is my modified 501)
Forum was a bit up the creak earlier which is probably why you couldn’t upload a picture but I think I have sorted that now
Posted: 05 Aug 2021 11:45
by clanger9
Thanks, TomI That explains a thing or three. Here's what mine looks like:
- IMG_0887.jpeg (187.54 KiB) Viewed 5909 times
The mod has been done rather well. There is a visible mark where the extra bit joins, but I figured this was a historic repair.
I guess the mismatched clock style should have been a giveaway...
Posted: 05 Aug 2021 18:37
by SupermotoDave
I’m more interested in the replacement fairing panel.
Posted: 06 Aug 2021 08:05
by nr.
I fitted a little charging indicator light to mine:
- img_20210718_202253.jpg (186.67 KiB) Viewed 5870 times
Easy to fit, and seems to be working nicely so far. I got it from
https://gammatronixltd.com/epages/bae94 ... BIKE-E-12V - although if you buy from their eBay shop, postage is free.
Posted: 06 Aug 2021 10:46
by huub
A moto guzzi voltmeter is easy to find, and should provide the same info.
