Camel Fork Brace
steve pegg
Camel Fork Brace
Post by steve pegg »
I need a front fork brace for an 87 Mk3 Camel . The Tarozzi factory is in some sort of paralysis, Disco Volante and Guzzi Bits unable to help. So fork slider diameter is 58mm ,distance between centre of stanchions 180mm should anyone have a box of them in their shed !!
Other fork braces are available.... so if an alternative can be recommended that would be great. I have tried ebay but dimensions are not given for any braces advertised.
Thanks Steve Pegg
hombre
Re: Camel Fork Brace
Post by hombre »
There is a guy advertising this in NL, funny because there are probably two or three over here, but maybe it is of help to you:
https://www.marktplaats.nl/v/motoren/on ... 86-27-0018
steve pegg
Thanks for the link, unfortunately nothing came up for fork braces.
The quest continues!
