The real treasures are located underneath my bed (my wife is delighted) and not in the garage so I can offer some more information:
Measured with a caliper (not the circumference on the flywheel!)
Distance between PMS and ANT 350:             43mm
Distance between PMS and ANT 500 :            37 mm
So it´s quite easy to see if you have a 350 or 500 flywheel in your hands.
The 500 flywheels are suposed to be heavier than the 350, the ...97 and ...98 suposed to have stronger magnets. But who knows what had happened before, falling down or overheating will reduce the magnetism.
my flywheels
...96 with starter rim obviously for 350:                        1798 gr
...98 with starter rim all marks for 350 and 500:            1907 gr.
...98 without starter rim (eliminated) all marks:         1616 gr.
a friend mentioned in La Straga in 2012:
...95 with rim for 500:      2680 gr
...95 without rim for 500:      2429 gr
...96 without rim for 350:     1524 gr
...97 without rim for 500:      2637 gr
...98 with rim for 350:     1931 gr
...98 with rim for 350:     1921 gr
his ...98 only had marks for 350!
Some of my friends have given to remagnetize their flywheels ... all without satisfying results
If you have to choose between two flywheels you can try to "feel" their magnets for example by lifting them with to chisels. or something like that. The better way is to measure the AC voltage of the green cable at idle. There should be at least 90V AC (if the coil is ok). Trying the two ones you will see, which one has the better magnets
