Woodruff key. 500.
Posted: 23 Jul 2024 19:13
by Arfer Job
I’m looking for a woodruff key for the flywheel/stator on a 500 sei if anyone has one kicking about in their spares box. Thanks.
Re: Woodruff key. 500.
Posted: 23 Jul 2024 20:07
by julianharty
Have you checked with mdinaitalia, they have various new woodruff keys for the 350 for instance and aren't expensive in the grand scheme of things...
Posted: 23 Jul 2024 21:37
by Arfer Job
I think when I looked it said out of stock but I’ll give Doug a ring to check. Thanks.
Posted: 24 Jul 2024 13:56
by George 350
You can easily make your own from a suitably sized washer. Find one of the 'correct' radius and cut off a slice.
Woodruff keys aren't hard, nor do they provide drive (the taper does that) - it is simply there to locate the flywheel at the right point on the crank so that the marks mean something. When in the crank slot it shouldn't be more than a mm high.
Also, woodruff keys are a generic item and available from many engineering suppliers/ fastener stockists, so worth a search on places like simply bearings etc.
Hope this helps,
Posted: 24 Jul 2024 15:31
by Arfer Job
Thanks George. Useful info.
