Alloy rim wire wheels for 350 with front disc
Stempy
Post by Stempy »
Wanted set of alloy wire wheels for 78 sport with front disc brakes
hombre
Re: Alloy rim wire wheels for 350 with front disc
Post by hombre »
Hi Rick, I have a front hub of a 125 to fit one disc brake for you if you want to build something. Also a GT-rearwheel with a usable drum brake if you are not after the original. Regards, Hans
huub
Post by huub »
I should have a front wheel somewhere in the stash,
isnt the rear wheel the same as the drum models?
The wire wheel Hubs of the Strada are 160, the Sport ones 180 mm. The brake, plate carrier and bored half axle of the castwheels fit to the 180 hub. These parts are diferent for the 160mm hub.
Stempy
Post by Stempy »
Thanks gents will be in touch
hombre
Post by hombre »
huub wrote: 11 Nov 2025 13:54 I should have a front wheel somewhere in the stash,
yes it is, 180 drum, all the parts, are interchangeable with later models (except the hub itself off course)
