Rear shock absorbers - 300mm
Maestro, SEI-V
TimClarke
Post by TimClarke »
I would like a new pair of rear shocks and would be grateful for any recommendations. The current ones are 300mm between the centre of the mounting holes. Many thanks
Re: Rear shock absorbers - 300mm
Post by simonnorthroad »
YSS if on a budget, Protech if looking to spend Koni/Ikon type money but want something state-of-the-art: multi-adjustable preload and damping, light, custom-built for your combined-weight/useage, rebuildable, UK-made
Stempy
Post by Stempy »
You could try YSS, i have had a a set for another motorcycle and found them excelent ,
http://www.yssshocks.co.uk/products.html
Eco line ?
TimClarke
Post by TimClarke »
cHEERS!
123morini
Post by 123morini »
Hello ,
I just have a look at your subject . In fact 300mm between centers are only for 350 .
On the 500 the rear fork is longer + or - 60mm compare to the 350 .
Than on the 500 the shocks the lenght is 320mm between centers .
Christian , 123 .
Top is from a 350 and of course the botom is from a 500 .
The lenght of a 500 .
And here the lenght of 350 .
123morini
Post by 123morini »
Re -
Here are photos of the lenght of shoks .
the 350
the 350
the 350
the 350
123morini
Post by 123morini »
Re-re ,
The lenght of the 500 ...
Christian , 123 .
The lenght of 500
The lenght of 500
The lenght of 500
The lenght of 500
Nice to see the frame next to the brake fluid reservoir has not been damaged by brake fluid weeping.
Dickyboy
Post by Dickyboy »
Judging by other posts on the forum & my own measurements, something nearer 312mm eye to eye is correct for the 500
TimClarke
Post by TimClarke »
Cheers matey
