Hi 500 people,
I have a question over on the 3 1/2 forum about colour schemes that someone here may be able to answer.
viewtopic.php?f=4&t=1497
DD
Correct colour scheme
Re: Correct colour scheme
Hi there. There was no 350 like this but the 500/6 (Sei) was similar. It used a red flash over black, or silver flash over red (similar to yours). The base red was also quite light, as yours also appears to be. The flash on yours isn't a 'correct' Morini pattern/shape however, as it looks like someone has tried to do a cross between the pattern on the early 350 Strada and that on the 500/6.
Pete
Pete
Hi Pete, thanks, I came to much the same conclusion. A "tribute" paint jobbie. Are you aware if the 350 and 500 tanks fit each other?
Dom
Dom
