Pick up connections
nerothecat
Pick up connections
Post by nerothecat »
Can anyone which lead from the pick up goes to which transducer? Both are red but one has a little white ring on it. I'm think this must go to the transducer that is connected to the front spark plug, am I correct?
Re: Pick up connections
nerothecat wrote:Can anyone which lead from the pick up goes to which transducer? Both are red but one has a little white ring on it. I'm think this must go to the transducer that is connected to the front spark plug, am I correct?
Yes.
alfie600
newtral detector
Post by alfie600 »
can anyone tell me where to find the neutral detector on my 500 strada ??
Re: newtral detector
alfie600 wrote:can anyone tell me where to find the neutral detector on my 500 strada ??
Did they ever fit one on 500 roadsters?
I've only even seen them on Excaliburs and Darts although the idea of fitting one was obviously there from the start of production.
Where a neutral switch is fitted, It's mounted on a boss under the right hand cover near the clutch push rod.
