Measured brake force
Posted: 20 Apr 2023 21:13
My SEI-V had it's final mandatory MOT today, it will be historic next year.
It passed, but the tester commented that the brakes were about half as effective as a modern 125 learner bike. 55Kg force was measured both front and back.
I was wondering if anyone else has data from their brake tests?
The tester commented that modern riders wouldn't be able to ride it safely, but 'experienced old guys were OK'!
In 1980 with my first 500 I considered it one of the best braked bikes on the road being fairly light and unusually for those days, triple disks, I could easily out brake friends on other bikes.
Nowadays with this 500, braking is clearly not as good as the 4 pot brembos on my BMW, but much better then my Laverda TLS drum brakes, I would still rate them adequate to good.
This has set me thinking is it time and memory + technology changes which make me think these brakes are maybe not as good as my first 500 or are they suboptimal for Morini disks? Also how would a single disk front brake on a 3 1/2 measure up?
I'm aware of improvements from fitting smaller master cylinders, though that is presumably not improving the brake force, just reducing the effort required.
I've not checked my pads other than a visual inspection of the thickness, nor stripped calipers or master cylinder. I have fitted new hoses and fluid without noticing significant difference.
Just a curiosity at this time.
