Page 2 of 2
Re: clutch spring nuts seized
Posted: 15 Nov 2023 22:04
by Steve Brown
The clutch assembly is the same on all the air cooled V twins. So if listed for a Kanguro then fine. It's probably because the Kanguro was a big seller in many countries so the most common model.
Posted: 20 Nov 2023 11:03
by terrys31/2
Hi Tim,
Damn! i wish i had seen this thread before i had to resort to drilling out one of my clutch studs after it broke free and started turning in the hub!!
So i now have a very nice, hardly worn, clutch hub with a drilled stud?
Question, has anyone got any suggestion's on a repair, maybe with a stud from a worn hub? Or a usable replacement for sale.
Posted: 20 Nov 2023 11:26
by Tim
bad luck Terry although if it was turning it may have been of limited use
returning to my query about clutch plates - these are advertised on fleabay but the 500 sport is pretty much the only one not listed. Just to be on the safe side - can I be certain they will fit?
https://www.ebay.co.uk/itm/266358381028?
Posted: 21 Nov 2023 15:05
by mbmm350s
Tim wrote: ↑20 Nov 2023 11:26
350 all models including Kanguro and 478 cc 500 used the same driving plates (composite)
3.5mm plates are Morini part 20.01.25
2.5mm plate are Morini part 20.01.24
There is One 2.5mm plate fitted first, then the rest are 3.5mm plates.
So yes they will fit.
Note Surflex catalog (Veterane) lists all Morini clutches and the required part numbers for full kits including the special dished plate (20.01.32)
Posted: 21 Nov 2023 15:17
by mbmm350s
Here are the SURFLEX kit part numbers with MM parts in brackets, you can check with vendor
Full set:
S 1149 Serie composta da:
5 articolo 2 M 77 (20.01.25)
1 articolo 62 M 39 (20.01.24)
4 articolo 62 M 43 (20.01.26)
1 articolo 2 M 131 (20.01.32)
driving plate set (fibre composites)
S 1149/B Serie composta da:
5 articolo 2 M 77
1 articolo 62 M 39
buona fortuna
Posted: 21 Nov 2023 18:20
by Steve Brown
I have also been guilty of telling everybody that the clutch centre is the same part on 350 and 500. Well, I owe you all an apology-I am 100% wrong!
The difference is the splined centre-it's larger diameter for the 500. I had thought the difference was just the steel bush and the bearings. Hey ho.
