Centerstand Spacer
Posted: 09 Aug 2025 18:20
by Tresette61
Anyone have or know where to get the centerstand spacer P/N 14.05.12. Which allows the mounting of the centerstand to the frame on a 500 frame.
Regards CLARK BERTRAM
Re: Centerstand Spacer
Posted: 09 Aug 2025 21:06
by morini_tom
The spacer runs in the frame tube and due to age and improper maintenance sometimes the tube/frame become wear items. You might find that even a new tube results in play if your frame is worn.
Last time I tackled this problem I reamed the frame to restore a parallel bore and then measured the new clean frame tube bore had a new spacer tube turned up to fit (it ended up with an OD about 0.5mm bigger than the standard tube)
It’s also worth fitting a new bolt at the same time. I’m not 100% sure about the 500 but my 350 was M10 x1.25 pitch,150mm long.
Grease it well when reassembling, or better add a grease nipple to the frame or bolt for future peace of mind.
Posted: 12 Aug 2025 19:40
by Tresette61
Morini Tom, thank you for the response and reply. Your info will help me in fabricating the sleeve spacer.
CLARK BERTRAM
