Charging Problem
Posted: 11 Aug 2025 11:07
I've been recommissioning a 500W (1978) and have completed about 200 miles in short(ish) test rides. With a fully charged battery it starts easily on the button but no charge is reaching the battery - no change in volts across the battery when the engine is running. Checked the alternator output - low values (10v approx) on the yellow leads and not halved when testing yellow/red. As I understand it that should mean the stator coils are the issue. Looking at the stator I think it's been rewound, no signs of damage and pre-insulated copper wire. I've look at several of the older threads on this subject but many are beyond my basic electronic knowledge.
Are there other tests I can carry out to confirm the condition of the stator?
Could it still be the regulator? Could I swap with my 1977 3.5 regulator?
Any recommendations of who could take a look/repair?
Anything else?
In a bit of a rush as had been planning to take the 500 to the IOM!
Thanks in advance
Andy
Anything else?
Thanks in advance
Andy
