Front caliper mounting bolts............
TimClarke
Post by TimClarke »
Does anyone know where I can get mounting bolts for my Strada please they are 10mm heads stepped down to 8mm I think........
Re: Front caliper mounting bolts............
M'dina would be the first port of call, followed by a wanted advert here.
TimClarke
Post by TimClarke »
Steve Brown wrote: 22 Aug 2025 12:47 M'dina would be the first port of call, followed by a wanted advert here.
The lower bolt, that goes directly into the fork has a fine thread! Don´t try to place a normal metric o inch srew!
For the upper bolt you will need a special spacer washer. Guess Mdina has them all.
TimClarke
Post by TimClarke »
Mdina don't have the bolts unfortunately
AntietamClassicCycle
When I needed one, I turned it out on the lathe, starting with an M10 bolt.
George 350
Post by George 350 »
I used a long 8mm bolt with a piece of tubing over it to take up the clearance between fork leg and bolt.
10mm tube isn't too difficult to get.
Regards,
TimClarke
Post by TimClarke »
Cheers matey
