Camel500 centerstand
Bertram3143
Post by Bertram3143 »
Members: I am looking for a center stand that fits a Camel500 from 1981thru 1983. I know they are rare as hens teeth. Any help would be appreciated.
Clark Bertram
Re: Camel500 centerstand
Sorry, but as you've found they are almost impossible to find. It seems the only way is to copy someone else's bike to get one made. The original is quite simple and lightweight construction. If you can do, or get done welding cutting and bending of steel it should be easy enough. I've just remembered there was a fellow in Italy who made batches of them. I think a bit stronger too, but sadly I can't remember the name!
I'm not aware of anyone making panels at the moment but the last ones I heard of were made by a firm called 'Sforza Racing in Lincolnshire UK. I think he may have closed but try googling that name maybe?
Angelo63
Post by Angelo63 »
I should have it. Let me check and send a photo.
Angelo63
Post by Angelo63 »
Tresette61
Post by Tresette61 »
Angelo: Thank you for responding with the photo. If you can post me measurements of the stand. I would need total length of the legs, width of mounting bracket, length of leg from bottom of foot pad up to bend. Also size of center-stand bolt including length. Sorry for all the questions.
Regards Clark Bertram cbertr@verizon.net
Angelo63
Post by Angelo63 »
OK. I'll do. Sorry, I do not read the forum often.
Angelo63
Post by Angelo63 »
Drawing of stand in your mail. Bye Angelo
'It must be a .....'
Hi, can the drawing be shared as someone is the UK is looking into getting a replica/s made to suit the Mk1 Camel?
Angelo63
Post by Angelo63 »
OK. This is the drawing.
Great, many thanks for taking the time to do the drawing and sharing it
Much appreciated, Ian
