Kangaro sprockets
Posted: 09 Oct 2015 20:57
by acemorini
Evening, my x3 Kangaro has a 47 tooth rear sprocket and 14 tooth front sprocket which is ok it goes like a rocket of the line, what size sprockets does everyone else run on the road.
Regards Pete
Re: Kangaro sprockets
Posted: 11 Oct 2015 19:16
by MickeyMoto
Hi Pete,
I changed mine to make it more relaxed on the motorway. I need to have a look next time I'm in the garage. I'm sure I changed the front sprocket and the rear. Gave Rob at NLM a call, he told me which ones to use.
Posted: 11 Oct 2015 19:42
by acemorini
Hello Mike, thanks I will give them a call next week.
Regards Pete.
Posted: 15 Oct 2015 18:47
by Jem
My X3 has a 44 tooth rear sprocket which gives a a nippy ride around town. These are available off the shelf (well, out of the catalogue), in steel or aluminium, from any useful bike dealer. You don't have to go to NLM.
The standard gearing on Stradas & Sports (38 teeth) is way too high making 5th & 6th overdrives. I've used a 40 tooth rear on my Sport which is much nicer around town and 6th is still a relaxed cruising ratio.
Posted: 15 Oct 2015 20:12
by acemorini
Thanks Jem, I have not got round to phoning NLM, but hunting around in the yard looking for something else I found a 44 tooth rear sprocket, so I will give that a go.
Regards Pete.
Posted: 17 Oct 2015 15:44
by acemorini
Fitted the 44 tooth rear sprocket this afternoon, what a difference it makes, still accelerates llke a rocket, but much better on fast A and B roads, went for a quick spin around the block and ended up in Eastbourne.
Regards Pete.
