last year I had the front wheel on my Kanguro rebuilt. When I came to check the wheel alignment last week I discovered the the rim & tyre are offset 4-5mm towards the left hand (disc) side. Can anyone tell me if this is this right?
I've heard of rear wheels being offset to get the chain line correct but always assumed that front wheels should be central between the forks. The hub itself is central - there is a minimum of clearance between the speedo drive and right fork leg already.
Kanguro wheel alignment
wheel alignment
Robin,
thanks for the offer. If you can say what the offset of the rim from the fork leg (either side) is and let me know what the width of the rim is I can compare.
Jem
Jem
