125 Corsaro
Godden 89
125 Corsaro
Post by Godden 89 »
Having replace my oil pump and kickstarts return spring and change the oil. I now need to remove the cylinder head and barrel to replace the gasket under the barrel. What I need to know is the torque figures for the head and barrel. I will look a the valves and guides while I have it apart. Possibly new rings if the bore isn't too bad, if it needs a rebore what is the availability of over size pistons.I dont expect too many problems, famous last words as it was running nicely with no smoke prior to replacing the oil pump, just the slight leak from under the barrel
