Jobs that are quite tricky with only two fingers working properly on one of your hands. No.1 in an infinite series: putting on a new Morini throttle cable when using PHBH28 carbs. I finally worked out a strategy. The 375 has no filters on currently (borrowed for the project) so I unshipped the front carb to allow the top to be removed without getting the tank off. Getting the throttle inner cable attached was a bit fiddly but I managed to keep the spring compressed with the V-sign only hand while getting the slide back on. Imagine my delight when I discovered that once hooked up to the standard Verlicchi twist grip the slide was half open! Even with the carb top adjuster wound in it still is
Checked the specs. on the Venhill website: 250/350 SPORT MODELS, FRONT CYLINDER | MORINI PART NO 36.01.26 | 774mm Outer | Clearance wire from ferrule to carb nipple set @ 78mm (3 1/16"). That's exactly what this one is, but the clearance is at least 10mm too short. Looked at the old ones that got trashed in the off. They are Venhill ones with midway adjusters (well a few cms from the twistgrip) that have been on for years. They clearly have more clearance (with those adjusters wound pretty much right in to be fair). Annoyingly Venhill don't give a spec. for the 500 cables but I'm guessing those have more clearance to suit PHBH carbs? I must have just got lucky 30 years ago.
I've ordered a couple of universal throttle cable kits for the project anyway as that's the best (only safe?) way to use the twistgrip cable adjusters on the fancy Tommaselli QA unit. Lots of careful measuring will be required before cutting to length, though what will suit the current handlebars in terms of outers will suit anything. Then I'll modify these for the 375, possibly incorporating the adjusters that come with the universal kits. The project is definitely going to get bar end plugs/weights this time, even if I don't fit 'bark busters'.
Might as well do the NLM ignition module and super-whizzo coils conversion next.
Gilera: 1957 175 Sport
Honda: 1984 CB250RS
Wishlist: 2026 Morini 350
