The silencer on my X1 is a little too loud, it is a Lanfranconi MM62 so a standard one for 1983, but it looks as if the end has been drilled out so I am hoping to make up a replacement end as per the standard arrangement.
Does anyone have a photograph and description of the end of an MM62 please?
Many thanks
Ian
X1 Silencer
Ian_C
X1 Silencer
1974 350 Strada
1975 350 Strada
1983 X1 Kanguro
1975 350 Strada
1983 X1 Kanguro
Patrick Slatts
Re: X1 Silencer
Hi Ian,
Bit late to mention but will do anyway...
I too had the same 'it's a bit too loud' issue with the MM62 silencer. I bought an OEM standard baffle from NLM (the last they had available at the time). The baffle is supposed to be held in place with a locking screw via a threaded pillar on the body of the silencer. This looks to have rusted away so the baffle is help in place simply by being an interferance fit. I know from earlier reaserach the diameter of the baffle is 60mm.
It's still loud but much better (and less anti-social) that hither too.
I'm happy to persuade it out to take further measurements and more photos if it helps?
Cheers, Chris I.
Cheers, Chris I.
- 20180607_084914.jpg (297.98 KiB) Viewed 5412 times
Ian_C
Re: X1 Silencer
Hi Chris
Many thanks for the photo of your MM62 - I also modified my silencer and it is a bit quieter now - I put a circular disc in front of the inner pipe and supported it with 4 radial webs, photo attached. Although non standard, the bark has been subdued to a more acceptable level.
Best regards
Ian
Best regards
Ian
1974 350 Strada
1975 350 Strada
1983 X1 Kanguro
1975 350 Strada
1983 X1 Kanguro
