speed wobble
dougi
speed wobble
Post by dougi »
:?: can any one list the possible causes of a mild speed wobble at 80mph with out stearing damper fitted.i think if i fitted a stearing damper it would just hide the problem :?:
3narf
Post by 3narf »
Correct me if I'm wrong (somebody)- this sort of thing normally originates at the back wheel, doesn't it?
Could it be a combination of worn s/arm bushes and squared-off back tyre?
dougi
Post by dougi »
it just passed its m o t 100 mile ago.so swing arm bushes should,nt be the problem.the rear tyre shape is ok i am puzzled by it :?
3narf
Post by 3narf »
Is there any chance the head bearings could be too tight?
dougi
Post by dougi »
now there,s a thought :D
corsaro chris
Post by corsaro chris »
Alternatively you might have a slightly over-sized rear tyre?
dougi
Post by dougi »
as i said before it passed its m o t 100 mile ago and today i checked the the head bearings for play,wheel bearings,forks,shocks and swing arm bearings. the only problem i found was----------a little play in the swing arm bearings !!!! so much for the m o t :x :?: :?:
