Hello All,
A question for the Morini Motor Mavins  in the UK….
I have an "A" pulley installed and the belt tension is a little too loose for my liking.
Question: If install a "B" Pulley (which I have) will it tighten up the tension or loosen it more???
Thank You in advance for your expertise,
Robert "Smitty" Smith
Red Baron LSR
California
						"A" Cam Pulley vs. "B" Cam Pulley
Re: "A" Cam Pulley vs. "B" Cam Pulley
it will tighten up.
A is the smallest pulley, C the largest and B is suposed to be the norm.
0.15mm difference in pitch diameter.
