As the heading says. The cartridges, not the springs or sliders. Any clues ?
Cheers.
Wanted, Mk1 Camel front fork internals.
- IMAG3845.jpg (69.7 KiB) Viewed 3267 times
Re: Wanted, Mk1 Camel front fork internals.
Is it the long version of the very first series? If not you can try internals from an Excalibur. The second and third series have fork tubes with the same length. I have fitted them to a Camel once. Only thing is that the tube wall (if I'm saying this right) is thinner so don't do very high jumps
See this pic, the lower parts are from an Mk II Camel the top ones from an Excalibur. Hope it helps.
Sorry, I didn't see this reply till now. I have decided to just live with the suspension as is.
Thanks for the info anyway.
Cheers.
Cheers.
