Camel woodruff key
forzamacchi
Camel woodruff key
Hello everyone,
I am the new owner of an 81' Camel. The bike is just about to hit the road after some upgrades and repairs. The bike had been running rough and I discovered a sheared woodruff key. Does anyone have the correct measurements so I can source a new one? I have temporarily created my own by cutting down a larger key, but this is obviously a short term solution.
Thanks in advance!
Ben
Thanks in advance!
Ben
1981 Morini Camel 500
2019 Husqvarna Svartpilen 401
1967 Aermacchi 250
1958 FB Mondial 175 Superturismo
1957 Ceccato 125 Sport Lusso
1955 Sterzi 125 Turismo
1967 Aermacchi 250
Re: Camel woodruff key
If you mean the key which locates the flywheel / stator, I don't think it's essential as there are no 'trigger points' involved (apart from the timing marks), so the running of the bike will not be affected. The taper and torque of the nut should hold the flywheel in place adequately. I may have a spare key I can measure (if I can find it's 'safe' storing place).
Unless the 81 has Kokusan ignition!
Welcome Ben, which model is it? How about some pics?
Presuming you are talking about the alternator rotor key according to what I can see it's part number 28.01.16 and dimensions are 3 x 5R 6.5
You will find this a pretty handy resource..
https://drive.google.com/drive/folders/ ... E1GeGtFZVE
Kamel.
Kamel.
forzamacchi
Yes! That was the location I was referring to.... I actually think what happened is that I loosened, inspected then failed to re tighten....lol.... Thank you! BenMing wrote:If you mean the key which locates the flywheel / stator, I don't think it's essential as there are no 'trigger points' involved (apart from the timing marks), so the running of the bike will not be affected. The taper and torque of the nut should hold the flywheel in place adequately. I may have a spare key I can measure (if I can find it's 'safe' storing place).
1967 Aermacchi 250
1967 Aermacchi 250
forzamacchi
Hello Kamel,
It is an 81' MK1 Camel. Ming was correct as I was talking about the flywheel over the stator. WOW! That is a fantastic resource. Thank you so much! Ben
Kamel wrote:Welcome Ben, which model is it? How about some pics?
Kamel.
1967 Aermacchi 250
1967 Aermacchi 250
forzamacchi
Hello again Kamel,
The dimensions of the woodruff key would be 3mm wide, 5mm high, 6.5mm long? Thanks, Ben
forzamacchi wrote:Hello Kamel,
Kamel.
1967 Aermacchi 250
1967 Aermacchi 250
Hey Ben, apologies, I've been busy with other classic vehicle ownership issues.
Yes i believe that is the right way to read the dimensions.
How about posting some pics?
This is my recently completed Camel Mk2 (well I think it's a Mk2).... Cheers,
Kamel
Kamel
forzamacchi wrote:Hello again Kamel,
Kamel.
forzamacchi
Hello Kamel!
Your bike is quite lovely..... My bike should be ready for the road today! I will take plenty of photos....fingers crossed. Ben
1967 Aermacchi 250
1967 Aermacchi 250
forzamacchi
1967 Aermacchi 250
1967 Aermacchi 250
Very nice Ben !
That a steel tank?
That a steel tank?
forzamacchi
Thank you! Yes, it is a steel tank... Ben
Kamel wrote:Very nice Ben !
That a steel tank?
1967 Aermacchi 250
1967 Aermacchi 250
forzamacchi
Thanks!
Steve Brown wrote:Nice!
1967 Aermacchi 250
1967 Aermacchi 250
